Happy_Jack
- Joined
- Aug 13, 2009
- 41
I know it is a common problem with the plastic float bowls on the mid 80's V4 motors. Has anyone been successful in sanding them on a flat plate to resolve the issue with sealing?
I know the newer brown rubber gaskets are much better than the old "paper" type, and i got my carbs to seal (1987 Johnson 90hp) , but there is no question the bowls are slightly warped.
I will replace them with either a good set from a parts motor, or order a pair of the metal bowls over the winter.
Just curious if anyone had lapped the plastic flat using a flat plate, belt sander, or something else? obviously a thorough cleaning is in order after the fact..
