Re: Washdown pumps
I think that tossing a hose over the side would last about one trip with me. Once you have a wash down system you're not going to settle for anything less than on-demand water anytime you want it. We keep the boat generally clean all the time now days, including the gunwales when that old rule - ladys go inside (porta pottie inside the cabin), guys go over the side - comes into play. Of course there's the fish blood to clean up too, but its just a squirt away to take care of it. On our system I use a short, 15 foot section of hose that is permantely connected.<br /><br />My whole system works like this. First there is the water inlet, which is a 1" bronze pickup. Go ahead and drill the hole in the bottom, quit worrying about it. Its no big deal. On top of my thru hull I have a 1" ball valve. I do not use a standard sea **** . On top of the ball valve there is a 1" check valve and then it reduces down to 3/4" hose. As mentioned, double clamp it with good hose clamps. By the way, you can buy good hose clamps at the local hardware, just make sure they sell you the ones that are used on submersible pumps. these will have full stainless heads on them, to include the worm gear screws in them. From the inlet side the hose goes directly to the pump, which is a Groco in our wash down system. the outlet of the pump goes to a T-fitting. One side of the T-fitting goes to the pressure tank and the other side goes to the water hose, which has the pistol grip nozzel on it. We just keep it stashed in a locker space, sort of curled up. Because the Groco unit is pressure switch controled (with pressure constantly maintained by the check valve that is back there at the ball valve) it remains on at all times. The pressure tank I use means that it doesn't cycle until about a gallon of water has been used. That's nice because the pump is actually a big power consumer.<br /><br />I think that the main thing you have to get away from is the fear of drilling that hole in your boat's bottom. Just do it, its not going to leak, you are not going to hit something and knock it off, immediately swamping the boat. Its not even goig to hurt it if you run aground. Its really no big deal but its the first step towards having a real system. Anything less and you might as well just keep on dipping that 5-gallon bucket over the side.<br /><br />Oh, I'll stick by what I said about ShurFlo pumps. In my experience with them they are utter junk and I not only wouldn't buy another one for myself but, to tell the truth, I wouldn't install one on someone elses boat either. If someone wanted to use one I'd just let them stick it in there themselves, they don't need me to help them put junk in their boat. That's how strongly I feel about them. I'm sort of particular about every piece of equipment on our boat though. I consider everything on the boat, with the exception of the cassette player, a piece of safety equipment, and I will not have inferior quality stuff on our boat.<br /><br />Thom
