Took the Cobra out drive off my 1988 OMC 57.. My shift cable was seized and in the process of tearing it apart to change it I see there is oil and water in the Ujoint bellowsI.... planned on replacing the gimbal bearing and all bellows while doing the shift cable anyway but now that I see the oil I was wondering if it was just from the grease or could it be leaking in from the upper unit of the out drive Is.... there a seal or something that I should change to be safe or am I reading more into this than there is. I know when I had to do the bellows on my Alpha 2 summers ago it was leaking oil in from the out drive. I had to bring it in cause I din't have the special wrench to change it. I see in the exploded view of the Cobra unit that there is a O ring but thats about it. Also is changing the gimbal bearing on a Cobra similar to a Merc. I have a Chmer manual but I haven't' started looking up the specific procedure and thought advise from here could help me first.
Thanks guys
Thanks guys
