I have a Boston whaler rage 14 with Johnson 90 hp engine. I recently notice that the auto bilge pump will turn on after I start engine. Finally I check the engine while running it. I notice there is a small crack on the water box part of the engine. It is shooting water when the engine was running. It isn't much and the bilge pump can easily draw out the water. I would like to seal it up without having to remove the engine, as the leaking part is accessible. Is there any product that can seal the leak from outside the engine? Thanks
