chitownborn
- Joined
- Jul 13, 2007
- 178
hello iboaters, i got a water circulation issue with a chrysler 140 hp model no 1409h9. this motor has been sitting for twelve years in a garage, starts right up with a tap of the key, runs perfect just no water circ, because it sat for awhile with no use i changed the impeller, the fuel pump diaphrams & gaskets. the passage is clear from the thermostat down to the exhaust snout, i have a blockage some where between the water tube and the thermostat anyone have any ideas how to possibly clear it without having to pull the head & exhaust plate. i know its not the impeller or water pump cause i went as far as to change the whole lower unit with a known good pump. any ideas? thanks
