Re: Water coming in through bildge pump outlet?
Your boat should have a USCG capacity plate somewhere inside. It's aluminium and probably yellow and black. It will list the maximum weight capacity, maximum # of persons, and maximum horsepower.
If you exceed any of the values listed on the capacity plate the boat may be unsafe. Also, any insurance claim could be at risk.
I am a 1st time boat owner and a little slow....not sure what you meant by this. Specifically "vented".
Thanks,
Chris
Lifted from the internet:
What is a vented loop
Vented loop: inverted U-shaped pipe with a vent at the top, used as a section in discharge lines to prevent back siphoning.
Vented loops are a necessity on board for some marine systems. You have vented loops (anti-siphon valves) or should have them, as part of an engine exhaust system, or plumbing for bilge pumps, or the marine head. The reason you have them is to stop a siphon or backflow of water in the system. With a siphon, the water can travel the wrong way in a plumbing system. In the case of a marine head the water can go back into the toilet and overflow it.
Vented loops are simple devices and very rarely go wrong, but when they do the results are catastrophic. The boats potentially sinks!
