Hi,
I'm trying to help a buddy with his 1992 Reinell with a OMC 5.0L with a Cobra drive. Finally fixed all of the secondary problems associated with a rusted out steel fuel tank and got the boat back in the water today. Found out that we had two problems, a steady stream of water coming in via the transom, and broken bilge pump.
With a limited amount of time to inspect the transom (see bilge pump above), we found a pretty good stream of water coming from the hole on the lower reinforcing plate (wide U shaped piece at the base of the transom mount). We are pretty sure that the water is not coming directly from that area but dribbling down from somewhere. The stream was probably enough to fill a coffee cup in 15 seconds or so. As the water level was within a couple of inches of the oil pan, we returned to the ramp and pulled the boat out of the water.
From the outside of the boat, the bellows look reasonable (I know that this means nothing). The boat has had some lax maintainence in the past, but everything is very clean.
Any one have any thoughts on where a likely source of water intrusion would be?
This problem was noticed (but forgotten) last season when the fuel tank gave up. I checked the outdrive oil this spring for him, and the fliud at the bottom of the drive was pure gear oil, no water.
Second, as I fully expect the answer to be that we need to pull the outdrive. Can anyone give me a rough comparison of the differences between pulling this type of drive along with the replacement of bellows, etc, and the same type of job that I recently did with by '94 Volvo SX drive?
I have the factory shop manuals for my Volvo and he has a Seloc (I gave it to him after getting the Volvo manuals). I'd like to avoid convincing him to buy a set for the OMC, but I think that I hear this coming as well. However, time is pretty short (combined multi family vacation coming up) and I want to get started in the next day or so with pulling the drive.
Thanks in advance,
johnbo
Thanks in advance,
johnbo
