Re: water coming out around top spark plug?
I have heard of cracks developing around the spark plug hole because of incorrect tightening , maybe this might be the case.You never stated if the leak was from the spark plug hole proper or from the casting area around the spark plug, if the water is comming out of the spark plug hole itself, this tends to indicate a gasket problem, failure or incorrectly fitting . ie. Water being allowed from the water jacket into the combustion chamber. Strip the cylinder head off the motor ,have it cleaned and then crack tested, if all is in order, then reassemble using a origional gasket and recomended gasket sealers / cement,remember some gaskets are maufactured so as to eliminate the use of silicone type sealers, they are already coated with a substance, that when under pressure will assiat sealing,then all should be in order.<br />Kind Regards.<br />William Wright.
