Water coming out between lower unit and midsection
Buzzy
Hey guys bolted up the lower unit on my 1972 100hp Evinrude electric shift. Started her up on muffs lower unit worked great but I had water coming out the seam where the L/U bolts up to the midsection. Not sure if this is right, should I use a sealer there? Manual is on the way
Want to take her up to camp the weekend and is easier to work on at home, any help is great thanks in advance
Buzzy
rickdb1boat
Re: water coming out between lower unit and midsection
That is no problem at all. Normal...
Molaker
Are you sure water is circulating? You may have missed in aligning the water tube inside the L/U.
Buzzy
Re: Water coming out between lower unit and midsection
how would i check the tubes aligment? Felt like everything went up ok splines and tubes. Bolted in easy know any tricks?
F_R
You should have used sealer in there. However, there is no problem if it leaks. Just makes you scared something terrible is about to happen. That water coming out the seam has done it's job and is on it's way out anyway.
Buzzy
Well she is going to get wet on Saturday so if anything goes bad i will be here on sunday afternoon Have a great weekend guys thanks for the info
Buzzy
Joe Reeves
Sounds like you have it assembled properly. That occurrance of having water leak out that metal to metal area is normal, and it will eventually seal up with salt etc.
However, if it bothers you, simply loosen the lower unit retaining bolts and drop the lower unit down 3/8", then apply some Boat Armor Sealer 1000 (available at many stores) or what OMC used to call OMC Adhesive (don't know what Bombardier calls it) but the dealership would still have it in stock.
Re-tighten all bolts, wait a hour, that should do it. What excess sealer should ooze out you can scrape off.
