Water coming out bottom Carburator
superman
Hello I have a problem with a 1992 150 HP Force. There is water coming out the bottom carburator. Any help would be appreciated. Thanks.
superman
Re: Water coming out bottom Carburator
I should have said also the compression on all cylinders is 148 to 150.
Scaaty
Sure that water isn't gas?
superman
It is for sure water mixed with gas and oil. it is white and milky. The engine also puts out a lot of steam with the exhaust when it is running on muffs.
b.gagnon
The water is probably mixed with the gas and is settling down to the lowest point. Check the gas tank for water.
superman
There is no water in the gas tank. It occurs when the motor is running the water spurts out. This occurs only on the bottom carb and the plug does have some water droplets on it as well. The head has been pulled and the cylinder and piston looks good.
b.gagnon
Did you put a new head gasket on?
