water coming out exhaust holes
mrimike
Is there supposed to be water coming from the exhaust port above the pee hole.
At idle it pees strong out of the pisser, but when at wot water also pours out the exhaust hole above the pisser, just below the top cowling.
1998 200 hp johnson
Mas
Re: water coming out exhaust holes
If you're talking about holes in upper back side of the leg...that's normal...anywhere else...like the block...not.
MAS
mrimike
yep it comes from the holes in upper back side of the leg.. ok thanks for the reassurance.. im new to the outboard scene
Mas
Do yourself a favor and buy the OEM service manual and read it cover to cover. Even though you do ont have a problem now...one day you will and you'll have a "jump start" on the problem.
MAS
