water coming out of #1 spark plug?
STEMY
HELP!! i have a 1986 115hp merc outboard with water coming out of the top spark plug. the motor idles like a champ but when i give it gas it spits and revs really rough. brand new gas all fuel lines and plugs. any ideas?
Ram57
Re: water coming out of #1 spark plug?
Sounds like you have a cracked head.
STEMY
head doesn't appear to have any cracks. could it be the water jacket or a gasket in the head?
emckelvy
Inline Sixes don't have cylinder heads. The cylinders are cast as an integral part of the block.
The cover on the back of the block just seals off the large area where water circulates around, to cool the cylinders. The tops of the cylinders are machined flat and that's what the cover seals against.
It's very common to see leaks where the cyl block water jacket cover gasket seals right around the spark plugs. The fix is to pull the cover and replace the gasket.
Just watch out if you've run in salt or very alkali lakes 'cause the 1/4-20 bolts can get stuck and will break if you use too much force. Heat from a propane or MAPP gas torch, carefully applied, will help loosen the bolts. Applying a thin coating of Permatex #3 aviation-type gasket dressing will keep them from siezing up in the future.
For a "Quick and Dirty" fix to get you out on the water, seal up the leaking area with RTV. Pull the spark plug out and use a suitable degreasing solvent to clean the area. Clean the spark plug too. Stick the plug back in and seal right around plug and cover. If you use black RTV it won't look too nasty!
Very likely that the water spilling out from #1 hole is shorting out the plug wire and causing a misfire/poor running. So, fix that up first then see if the problem goes away.
HTH..............ed
What if the piston has a bad wrist pin and worn a hole all the way through the cylinder into the water jacket?Will that glue stuff fix dat too?
STEMY
if i just seal around the plug how does that stop the water from shorting out the wire? wouldn't it just cause the water to "wash" around the plug?
