water coming out spark plug hole
gema
we have a 1976 evinrude 75643d/j0004014<br /><br />the motor will sit and idle,but when but in gear it died.<br /><br />pulled pulled plugs, and on the bottom plug it appears to have water<br /><br />any ideas? is the motor junk?
The Marine Doctor
Re: water coming out spark plug hole
Likely a blown head gasket...not a serious problem...Just take the head off...clean the old gasket off and replace with a new gasket.<br /><br />In serious cases..you may have to plain the head.<br /><br />TMD
The Marine Doctor
I might also add...check for damage to the cyl and piston.<br /><br />TMD
gema
we have replaced the head gasket,and visual inspected the cylinder.<br /><br />and water is still getting into the bottom cylinder.<br /><br />what now?
The Marine Doctor
Blown base or exhaust gasket...you will have to pull the power head to check both of these.<br /><br />TMD
Mettaree
gema: Are you sure there isn't any water in your fuel tank. Water sinks - fuel rises, pickup tube is at the bottom of the tank..<br /><br />Fair Skys
gema
cap yes, pretty sure<br />will replace the other gaskets, then get back with you. thanks
