New to the site, and thought I would ask a question that I would have liked to ask last summer. My carbs on my 1995 Merc 60hp (actually a 45hp jet drive, but 60hp powerhead)sweet a good deal of water. So much in fact that the the water will get into the throats and cause the milky color inside them. A mechanic told me that condensation is normal, but it causes it to run badly and doesn't appear normal to me. After running for about 5 minutes the carbs will be completly covered in water. It also dies on me sometimes like it is running out of fuel. When I check the bulb it is very hard, like it is pressurized with air. To make it stop I have to remove the fuel line at the motor and releive the pressure in the hose. I don't know if the two problems are connected or not, but figured I would give as much info as I could. Also had a problem with the motor running lean in the past, but I believe that has been fixed.<br /><br />Sorry for the long post and thanks for any advice.
