Re: water cooling problem
Hi Buzzerr, no need to panic, you have three pumps, that's ok
<br /><br />Your engine has closed cooling system. Like regular car engines (There's your first water pump - the one on the block). The only difference is the radiator is called heat exchanger. It is not air which is cooling it but water from the lake/sea. This water has to be pushed through the heat exchanger by another pump, the one "hanging off to the left side". That's your second pump. To help pick up the water from the lake/sea, there is a third pump in the outdrive, often referred to as the "impeller"
If you found rubber crud in your secondary pump, it most likely comes from the impeller which fried and bursted into thousand pieces. That's why you don't get any water in your secondary cooling system.<br /><br />As it was already said here, you need a repair manual for your boat. Search on-line, you can find them from $25.<br /><br />The rubber impeller is somewhere in your outdrive (usually above the prop) and replacing it takes maybe an hour and costs just a few bucks (depends on the price of new impeller and seal).<br /><br />Hope you can find the manual and parts quickly so that you can enjoy the summer.<br />Lou
