water decarbinazation
tie_one_on
If doing a water decarbinazation would it be better to use a small stream of water from like a dish washing soap bottle or a by a spray bottle? Or wouldn't it matter.
Re: water decarbinazation
I've never Tried anything but a Soda Pop Bottle........<br /><br />A 16oz. bottle full,....With the motor Running,+ Warmed up,......<br />Rev it to 1000/1200rpms,......<br />You'll need to pour it Fast enough to cause it to Labor,... But Not Stall....Right Down the Throat of the Carb.........<br />When the bottle is Empty,.....<br />Your Done....... ;) <br /><br />I Don't think the methods you ask about will move Enough water, Fast Enough..... <br /><br />Do a Search,.... I've posted the routine here,... As per my British Leyland/ Land Rover Ser.I/II/IIA/III Shop Manual.........<br /><br />If I Know I'm going to be tearing down a motor,.... I do this 1st.... Saves Alot of Time later.....<br />Pistons,+ Combustion Chambers will be as Clean as New..........
tie_one_on
Thanks, I wasn't sure if it was the volume or just the water that did the job.
