Re: water deflectors
I just changed them on my 1992 115 Johnson this past weekend because I had a lot of salt deposits in the waterflow passages to clean out. Someone mentioned in the forums that the deflectors can sometimes swell and restrict the water flow, and they should at least be inspected. Mine didn't look "swollen", but I changed them as part of the cleaning.<br />The OMC Tech manual I use didn't say to use gasket sealer when putting on the head gasket, (they were aleady kinda tacky out of the package) so I wouldn't think that taking them back off to change the deflector would be a problem.<br /><br />Also someone mentioned in the forums that you can just use 3/8th inch O/D rubber fuel hose, cut to fit the length of the old ones, to replace the deflectors...but I'm not gonna suggest that either way since I'm a newbie. Maybe Dhadley will have some insight on that.
