boating brad
- Joined
- Jun 7, 2003
- 201
i have a 1985 14ft bayliner capri bowrider i want to replace the floor in. i dont know whats under the floor (foam?)there is a drainpipe under the floor that runs the length of the boat but splits off to 2 pipes at the center of the boat (my battery compartment). the floor has a couple soft spots not too bad, but i want to replace it so im in the planning stage. the foam i believe is up front in the bow benches (cells) and in the back, square boxed foam cells on both corners of the back. im thinking that if i remove all four cells and glass in new ones "water tight". i wont have to put foam in them, since they will be water tight. what do you think? i have never heard of anybody doing this but it sounds good in "my" head. "displacing water in an airtight chamber"<br />just glass in the bottom and sides and silicone with screws on the lid and a heavy helping of glass on the outside.
