1984 Mercruiser
4 cylinder
self contained cooling
800 hours on engine
Here in Orlando boat is used often .
Check fluid levels often, engine covered with a tarp besides engine cover making sure everything stays dry
One morning this week after a 3 inches of rain night before within 2 hours, moving trailer too continue installing of new trailer fenders.
I hear water hitting pavement and glancing at drain , I see OIL pouring out of drain plug ????
Holy cow what happened ,?
Day prior everything seemed fine, started engine and ran a few minutes with ear muffs.
Today water and a lot of oil pouring out of drain
Upon further inspection pulled dip stick and oil level extremely high, grayish
Removed oil filter, it was loaded with water like a off white paint
Drained oil and it was the same off white ?????
Thinking with the 3 inches of rain in a short time somehow did water enter ?? There was some water in bilge but remember boat is tilted back, drain open,
no way did water reach engine . Plus with tarp no way could water enter
What would cause oil too come out and drop all over bilge without engine running ?
Self contained cooling that is full and have not had too add water quite sometime
What should I be looking for ?
On the 4 cylinder Mercruiser engine cooling impeller there are gaskets separating oil from water on the shaft.
Water could easily enter but I if I was loosing water I would be filling water tank ?
Was told too add a gallon of diesel fuel or mineral sprits , remove coil wire so engine cant start and crank a few times too clean everything. Wait a short while and drain . Do the same after fresh oil and filter and then start and watch it ???
No oil in engine a few days and do not want too do damage or cause rust too form .
What should I be looking at too stop water from entering my engine ?
thanks
Al
On a self contained cooling were can water enter engine ? .
Could water enter engine from this area since there are a few rubber seals separating oil from water at this point .
Water traveling too engine impeller is self contained water and water level is full
Manifold
He told me too pour a gallon of mineral sprits or diesel gas into engine remove coil wire so engine cant start, crank a few times , let it drop too oil pan and drain
Told me go two ways start pulling things apart but prior add fresh oil & filter and see if it leaks and how long it takes
He did say only two ways water can enter oil ? is that true
So fellow boaters here on this forum what does this sound like and what should I be looking for
4 cylinder
800 hours on engine
thanks
Al
Manifold
