Just put the out drive on my boat today. Alpha one. Got the hose with the ear muff looking things hooked up to it and ran the engine. everything looked fine but i was getting water form the prop. after looking into that that should be fine. it looks like the water should flow around the forward gear carrier and out the back of the carrier with means out the prop. After that I saw water coming out the engine all over the starter. Even with that things seemed fine. Water temp stayed steady at 160 at idle. After I shut it down and moved a few things out of the way I could see a hole in the engine just behind the starter. The dam casting plug is gone! the two in the front of the engine [ 228,GM 305] are there and fine along with the bake one on the other side of the engine. The edges of the hole look rough and rusted. could the plug have rusted out? cant find it in the bottom of the boat?
