andywhatling
- Joined
- Oct 29, 2009
- 4
Good eveing all,
I have recently had a water/fuel sep fitted by a marine mechanic during an outboard service. The outboard is running fine and really motors well but always needs neutral revs to restart once I have been sitting out on the sea for a while even after a good run? is this just normal for a 6 cylinder outboard?it is also a little sluggish at trolling/idle speed.
I checked the filter and it was quite messy. It is the "spin on" 35-807172 type, is it safe to flush/rinse these filters through for re-use or am I better off just replacing? I have an underfloor tank and expected to have to change the filter pretty soon after install as god knows what was in my tank previously??!
I am also wary about the install of the filter, the mechanic appears to have connected up the fuel line to the filter against the flow of the arrows on the mounting bracket/inlets & outlets? should the fuel from my tank be deposited into the centre of the filter via the threaded inlet and the filtered fuel pulled up and into the outboard via the perimeter of the filter? or vica versa....(hope that makes sense)
Hopefully simple questions for somebody out there.....cheers
