Water/Fuel Separator mounting?
imanavyflyer
Greetings!<br /> OK, I purchased a water/fuel separator. Not sure where the best postion is to mount it. Merc 3.0LX, SeaRay 175 Bowrider.<br />Thanks in advance,<br />Bob
zzzzz
Re: Water/Fuel Separator mounting?
as long as it's away from the heat of the engine,go for a place that's easy to get to and visible enough to remind you to change the filter OFTEN ! also, if you got a RACOR brand-on an I/O you must use the metal drain bowl/not the plastic ;)
imanavyflyer
Thanks zzzzz! So, depending upon where I mount it, I will probably have to run longer fuel lines? Plus, is it better to put it between the tank and the fuel pump or between the fuel pump and the carb?<br /> :confused:
FatBack
Tank and fuel pump.
