J70ELCSA, 1980 70hp, I have water in #2 and #3 cyls.
Just went thru all the other repairs (carb kits, fuel lines, plugs, thermostat, etc.) and finally started up in water.
Pees good. No overheating.
Compression 120 across all three. Spark good across 7/16 air gap.
Then I pulled the new plugs, and noticed water.
Now....where is this water coming from? From other posts, these engines are prone to corrosion in the exhaust manifold assembly. Is this the LIKELY place the water is coming from?
If so, what am I looking at regarding repairs? Broken bolts? Pull the powerhead? Any tips on this issue?
Or will it be just the gaskets......???
Trying to get a feel for the most probable cause.
DURBAN? Right down your alley....
Tom in Edgewater....isn't this the same engine you have?
