sublauxation
- Joined
- Oct 13, 2008
- 1,317
I just fixed a flat and was putting the tire back on and decided to check my bearings. About a teaspoon of water poured out so I took off the hub to have a look. The grease around the outer bearings is milky but looked clean around the inner bearings. There is rust on the spindle where the inner bearings sit. The inner seal looks like brand new. I thought the cap was leaking but why would the inner bearing surface be rusted more? There was plenty of grease on the inside. I've had problems with bearing buddies on a past axle but is this a good time to give them another try? Should I just clean this up with emory clothe or 1000 grit paper or is it fine as is?
Thanks for any and all input!
Chad
Chad
