wikiedickie
- Joined
- Jul 26, 2009
- 7
hi
i have a 1991 302 omc cobra four winns. i have the same problem last year with my boat as i do know. the gimbal bearing is failing. i am almost certain that it is from the water in the bellows. not sure how it is getting in there. i replaced the bellows last year so i know there are no rots or cut in it. the old bellos were in good shape also but i thought that was the problem the first time. so i replaced them. is there any other way that water can be getting in where the gimbal bearing is i put on a new gastket everytime i take off the out drive. i clean the surface good. i am so confused. also ccould water be getting into the boat causing the bildge pump to run from this problem? or is another issue. it seems like my bildge pump runs alot and the battery dies not sure where all the water is coming from. waht else can i look for to solve this problem and the other
thanks
sam
thanks
sam
