Zackman
- Joined
- Dec 3, 2005
- 376
I have a 99 350 Mag with a Bravo 3 drive.
This last winter was the first time that I winterized the boat, which included pulling all the blue plugs, replacing all the old o-rings, and filling the engine with antifreeze. Last season, when I would pull the drain plug, I would get at most a teaspoon of water. Now when I pull the drain plug I get a good cup or two of water. I've run the engine on muffs and cannot see any signs of leaks from the blue plugs and hose connection points.
Also, in the Fall (December) I pulled the drive and inspected the bellows and it was still very pliable and no signs of cracking.
Can anyone suggest a good method for trouble shooting the cause of the water leaking into the bilge?
