I have several issues I need help with:<br /><br />I have a 1996 Regal 258 Commodore with twin carbureted Volvo 3.0 GS engines with about 380 hours on each engine. The STBD engines raw water pump shaft broke and the engine overheated. After the pump was replaced the engine started and ran as though nothing had happened to it. <br /><br />After several uses the starter failed. I replaced the starter. Then the engine was very difficult to start or wouldnt start at all. I removed a spark plug to find it was wet with what I thought was gasoline. I turned the engine over with a single plug removed to verify spark. When the engine turned over, about a teaspoon of water came out of the spark plug hole on each stroke. I checked the oil and it had that creamy look to it. After reading your forum it looks like there is a good chance that it is a cracked manifold or leaking head gasket. <br /><br />My questions are:<br /><br />1) One of the forums notes mentioned to water test the manifold. How does one do this? How can I verify that the manifold is not the source of the leak?<br /><br />2) I assume that if the manifold is not the source then the cylinder head or gasket will be the source? How does one verify this?<br /><br />3) Another un-related issue is that the engine starter circuit does not always work. I have jumpered out the ignition switch and the neutral lock out switch without success. I have also replaced the Hella starter relay. I assume the issue is between the neutral lock out switch and the starter solenoid? Any words of wisdom on how to trouble shoot?<br /><br />Thanks in advance for your help
