water in cylinder?
cvflats
i was rechecking the compression and when i looked in the bottom cylinder after taking out the spark plug i saw some creamy white/green stuff. this could be water or maybe seafoam still in the cylinder from decarbing last night. how do i confirm and what do i do if it is water?
tashasdaddy
Re: water in cylinder?
compression check, should show a blown gasket.
cvflats
both cylinders were equal. guage read 50 but it was a rental and looked as if it had been dropped a few times. does this rule it out?
Benny1963
no *** doesnt rule it out ,50 is low ,but equal ,try another gauge .
i ran mine with one from auto zone ,it was lower than my snap on
probaly have blwon head gasket .with water in cyl ,
are your plugs unusually clean
cvflats
i took a close look at the gasket and it had a hole in it -blown i suppose. is there something i need to adjust or does this just happen sometimes? can i patch it with gasket maker? what do i need to do to get the water out before the it hurts the cylinder?
cvflats
are we talking about the cylinder head gasket or the powerhead gasket?
