+how you doing i am new to this site seen lota of good info , but i have a question this is my first boat 1996 sunbird corsair 200sl the preevious oner had it sitting for 4 yrs when i got the boat it needed some wood replacement a i also changed oil filter drained fule tank . had it in my driveway and had it running and running good till i put it in the water, putted around for a while through wake zones and was fine started openong it up after a 5min ride the right bank exhaust had gotten so hot it melted the coating off and the bellos melted and started leaking water. after this happened removed boots and cleaned them. stoped the leak. than had problem starting, but ran fine on the way back never overheated runs fine at higher rpm, runs rough at idle. we to get the trailer to load up left it ideling and stalled when i got back. tried to start it and was locked up. when i got home found water in 3 cylinders .
wondering if anyone knows if just the exhaust could be dumping water into the cylinders or if it is a headgasket. if in the exhaust how to test for leak
s
thanks for any help
s
thanks for any help
