Another retired guy
Ensign
- Joined
- Jun 17, 2012
- 940
Buddy of mine at next dock along came in from a run on the lake at idle speed. Said the engine was overheating. He shut it down and came back a few hours later to find that now it wouldn't crank. After checking usual electrical connections he removed one plug and saw water in the cylinder. He removed the remaining plugs and cranked it - water came out of all cylinders!
Marina says problem most likely a failed water pump and water has entered cylinders via the exhaust valves.
I am puzzled
How can an engine be idling fine at shut-down and then suck water into ALL cylinders when it's stopped?
Can someone please explain this?
Boat is an early 80's Sea Ray with ( I think ) a 4.3 Mercruiser.
Thanks.
I am puzzled
Thanks.
