I let my 2003 5.7 GXi sit for about 4 months and after I started it recently, I had a knocking sound. It sounded like a stuck valve to me, so I did a compression test and found compression on #5 was low (90psi). I also see some rust on the threads of a few of the spark plugs, including #5, and all the plugs were very black and dirty. When I pulled the valve cover off, I did find two rockers very lose on the same cylinder, but it wasn't #5, it was #7 which had the highest compression (160), which makes no sense to me.
I will play around with trying to get the valves unstuck by tapping on the rockers, and of course I may have a stuck ring or two as well, so will look into a leak down test.
My risers are original and I resealed them 2 seasons ago since they looked like they had a few years left in them, so not sure if the water is coming from a riser gasket leak, or from stopping the boat too fast. Is it an option for me to go to the tall risers just to be safer? I think I have room in the engine compartment, but of course the piece going down to the Y will have to be longer.
I also remember seeing some posts here a couple of years ago about stainless exhaust/risers but can't find much info on them now.
