I just bought a boat with a 1996 Merc 5.7 EX and Bravo III
The prebuy included removing the drive, visual inspection and draining and checking the drive fluid. All checked out but the drive oil was probably changed out when the boat was winterized in the fall. The drive was not pressure checked. I noticed water in drive resevoir yesterday while working on the boat. I have not run the boat yet. There is about a 1/2 inch of milky water on the bottom of the resevior. That seems like a lot of water to be the result of accumulated moisture. If the drive had a leak would the water work its way up to the resevior?
Henry
Henry
