1999 Volvo Penta, 4.3GL PWTR
I thought it was a starter problem. Called a mechanic, he said to pull one of the spark plugs and see if there was evidence of water. I pulled one of the plugs and water came gushing out!
I have been banging my head against the wall since then! I always intended to replace the manifolds as preventive maintenance, but never got around to it. I am of course assuming that it came in through a manifold.
I spoke with a mechanic and he reviewed my options. He said that usually the engine can be repaired as long as the water hasn?t gotten too deep (ie. past the cylinders). He talked me thru how to flush out the remaining water and squirt some CRC fluid into the cylinders. I am going to attempt that and get it over to the shop today.
I am going to see what the mechanic says after the diagnostic, but I will have some decisions to make. The boat is in fairly good shape ? I just had the drive rebuilt last season. Most external engine components have been replaced (pumps, starter, etc.).
My question is: Has anyone else gone through this? If so, how many more seasons did you get on the repaired engine?
