magicbandit
- Joined
- Nov 18, 2002
- 27
Hi Gang.<br />Thanks to Vinney for pointing me in the right<br />direction to solve my Water in the oil problem.<br />I found that the manifolds and risers are ok but the gaskets that connect them were leaking.I installed the new gaskets and pressure tested at 25 psi,and no leaks. throughout this process i removed the valve covers and cleaned the whitish/gray sludge out. Now that i have the motor all back together I have a question. how many oil changes will i need to do to get ALL the water out of the crankcase????
