Ike-110722
- Joined
- Sep 3, 2007
- 408
Checked my engine today for the first time since I put the boat in the water at the beginning of June. The oil is milky. Obviously water is getting in somewhere. Did not have this problem last year or at the beginning of this year. The engine is a Mercruiser 165 (GM 250) in line six. It is 42 years old. The only thing on the engine that hasn't been replaced is the block (and internals) and the head. It is raw water cooled. No heat exchanger. All new exhaust manifold and exhaust/cooling system parts. All bellows and gaskets on sterndrive and so on. It is only used in fresh water. And, the engine runs very well. Reaches max rpm at WOT and does 30-35 mph.
Anyway here is my plan.
remove old oil and replace.
replace oil filter.
remove plugs one at a time, look for water, and crank to see if there is water in the cylinders.
check compression on each cylinder
run engine until it gets up to normal temp and run it for ten minutes or more.
drain and change oil and filter again
run engine
check oil for water.
I suspect a leaking head gasket (had that problem with another engine) but no white smoke in exhaust.
Worst scenario, cracked head or block.
Have I forgotten anything I should check or left out a step?
Any other suggestions, advice?
replace oil filter.
run engine
