Water in exhust
SKIBUM1M
I have a 1966 johnson super seahorse v4 60 hp. It is not running as fast as it should and I have water spitting out with the exhaust as well as when i rev it in neutral it seams that the water in a trash can is bubbling and oil (maybe 2 cycle) in the trash can. I am thinking a leaking head gasket but i am not that familiar with boats. thanks in advance. also where can i get new headgaskets since iboats doesnt go that far back?
wilde1j
Re: Water in exhust
Are you talking about water from the relief ports on the back of the upper midsection? Or somewhere else?
tx1961whaler
Re: Water in exhust
The exhaust comes out underwater. Cooling water is supposed to come out of the relief port that is halfway up the back of the motor. The unburned 2-cycle oil gets mixed in the exhaust and you will see it in the water in the barrel.
What you have described is normal.
SKIBUM1M
Re: Water in exhust
This is an old outboard that the exhaust is just under the powerhead but above the water. Not thru the prop. So it gives a constant spray of water directly out the exhaust pipe. the water return is behind the prop
tx1961whaler
Re: Water in exhust
That is the exhaust relief port that is below the powerhead but above the water. It is supposed to spit water out of it; that is how you know the water pump is pumping water. The rest of the exhaust comes out from behind the prop.
