Looks like some bad (watered down) gas made it's way into my tank. Obviously no fuel water separator or this conversation wouldn't be happening. Pulled the main tank, drained/cleaned it. The question is can the water
already in the carbs be removed somehow? Dropping the bowl and dumping it worked on the lawnmower. Maybe a drain petcock exist? Will the water eventually run thru to motor? Trying to avoid carb teardown if possible. Will be adding fuel water filter/separator now for sure!
Thxs
Thxs
