Re: Water in Fuel Cell! -Help!
Ok, good! This has me going in the right direction?
Thanks,
Ill tell you how I found out I have water in the fuel cell.
Second time I took this boat out. I stopped at a gas station and filled the truck and boat. I launched the boat, warmed it up and took off and the engine died about 5 seconds later. Would not fire back up. Very disapointing, the enging ran solid the first time out, never died out and very easy to start. I got a short tow back to the dock and called the mechanic. I pulled the plugs to have a look and they were all wet. So we figured the plugs were fouled. I ran all over looking for plugs to no avail. Finally, four hours or so later, I loaded the boat up and drug it home. This ate at me and ate at me. I woke up the next morning and drug the boat to the mechanic. He dropped the bowl on the top carb and it was full of water, the second the same and finally some gas in the third. Sooo...at this point were thinking blown gaskets or something to that effect. Since I filled up the truck and boat at the same time with the same gas, I seriously doubted water in the gas, the truck was running fine. I was about to disconnect and leave the boat with the mechanic when we decided to pull a sample from the tank. The sample was about 15%water and full of trash. I was really glad to see the water in the tank. Didn't want to have to get back into the engine. I don't think the water came from the gas station, we had about two days of heavy rain and it must have leaked in some how. Either the vent or the fill cap. All is being replaced now I just need to clean the tank.
Thanks again for the suggestions,
TW
