Re: Water in Gas
The inline fuel filter that DB suggests is the way to go. Also, the 10 micron is a good size and is what I use.
If the filter assembly has a clear bowl then you can easily monitor the situation to see if you have any water present. If it is the more economical spin-on cartridge type (like mine), you can still monitor the situation but it takes a little more work. After it's been in service for a couple of hours, CAREFULLY unscrew the cartridge and pour the entire contents into a LARGE, CLEAN glass jar. You can visibly inspect the gas to see if you have any discolored gas or free water. If the gas is clear and clean, then it goes back into the tank. If the gas is milky looking or contains free water on the bottom, then there is water in the tank. Check the O-ring on the cap to your deck filling port. Also, take a look at the placement of the fuel tank vent. The vent on my boat was originally in a location that was constantly getting splashed.
If your area happens to be making the switch from conventional gas to 10% ethanol, you might see some yuk in the fuel for a while. If you have any free water in the bottom of your tank it will start to combine with the ethanol. This will continue until there is no water left. (If this was the case, I would remove the tank level sending unit and maneuver a piece of rigid tubing into the lowest reaches of the tank and pull out the water. I've done this before with good results.) Also, you might need to check all of your fuel hoses to make sure they are ethanol resistant.
It's really a good idea to to use some type of fuel stabilizer. There will probably be lots of follow-up posts on this subject. (Stabil, Seafoam, etc.) I've been using some stuff called Star Tron with good results.
