Water in gear oil - Test and rebuild tips 2000 Yam 30hp
jedimaster
I have a 2 stroke 30 hp yamaha andthe lower unit is leaking water into the gear oil. I pulled the lower unit in the fall so i could test and re do the seals, but where do i start and is it worth me doing myself? I think I read somewhere you are supposed to drain it and put 10 psi to the lower unti via the drain plug and listen for air? Any tips on where I should get started would be appreciated.
