water in lower case
rwcreigh1
hello,i just went to change the oil in the lower case on my 1984 johnson 35hp when i did this all thay came out was water.i changed it around 1 year ago.it has not been out in about 9 months and has been outdoors.what causes this and what seal or gasket needs to be replaced?and yes i ordered a manual fron ebay but is about 1 week away.is this a job that a person with little exper. on outboards can do.thanks
Docdoc
Re: water in lower case
Richard:<br />Sounds like your gearcase lube went out at some point when you were running it. There is no other explanation for there just being water in the case. You can probably install a seal kit yourself, be sure you get a complete kit of the unit amd replace all the seals. In the process, carefully examine all parts int he case (gears, clutch, bushings, bearings and propshaft for excessive wear, pitting or scoring. It is possible that there is some damage because they were not protected by the lube. I'd inspect the parts before installing the seal kit. You may need to replace some parts, or get another lower unit.<br />If you are uncertain of your ability to do this. Take the lower unit off and take it to a mechanic that you trust.
rodbolt
wow<br /> no telling how much damage is done. time for a tear down. refill it with motor oil until you can dissaseble it. rust wont form in the absence of air<br />the only special tool realy needed is the puller legs. they are not that expensive. they will work with a harmonic balancer puller. the three most likly spots of leaks are shift shaft,prop shaft and drive shaft.
Solittle
Your best bet would be to do a pressure/vacume test to see where it is leaking. One possibility - did you use new gaskets/seals on the fill & drain plugs when you changed it last? It could be a simple as that. You might try new fill & drain seals, filling it with oil & go for a test run bewfore you do a complete tear down.
rwcreigh1
no i did not add gesket seals on plugs.did not know i had to.does this need to be applied everytime?
Docdoc
I would just check the seals when you drin the lower unit. If they are crack or look bad, replace them. They are inexpensive anyway
