Bought my first "big" boat in September, 1998 Trophy 2503 Center Console with a 1998 Mercury 225hp 2 stroke EFI motor. Lower unit was pressure checked and checked for water when I got it. We used the boat 3 times and went through less than half a tank of gas total (150 gallon tank). When I pulled the bottom plug on the lower unit to change the oil today I was horrified when about 1/4 to 1/3 of a quart of water came out followed by the oil (boat has been sitting for 2 weeks). There was metal on the drain plug magnet. So-I let it drain very well then filled it through the top hole until the hand pump I was using had built up some pressure. Just above and forward of the top plug is a hole in the case. Some oil came out of that hole. I then drained all the fresh oil out very well and refilled it from the bottom hole. Prop spins smooth and tight and we never noticed any problems when we were using it. Being in the Northeast the boat won't come out of storage until March. What should I do next?
Note: The motor was always in fresh water and was very well maintained. It was stored 8 months out of the year indoors. It runs great and looks to be in mint condition other than this problem now.
