water in lower unit
missed_shot
I had water in my lower unit because it leaked in through the drain plug.I'm sure that was the problem. I drained and changed the oil after one short trip and fixed the problem. Now that winter is approaching, should I change the oil again to be sure no rust or freezing will occur of will the new oil protect everything. thanks :confused:
KCLOST
Re: water in lower unit
I would, this way you will possibly remove any water that remained in the unit from the last change, and also to check and make sure any more water didn't come in...
greasemonkeyozi
I always change mine out every 3 fishing trips just because I can.
missed_shot
wow - merc.grease - how many hours do you run in 3 times fishing ??
andrewkafp
It's only a 25HP, so it will take less than a pint of oil. Just change it regularly..
