I have a 1991 90 hp evinrude. I have water in the lower unit. I noticed what appeared to be pin sized bubbles coming from the split in the case between mating surface on lower unit. I am assuming this is where i am getting the water from. I plan on splitting it and resealing it. What type sealer should I use? Is it OK to use normal silicone gasket maker?
