Re: Water in lower unit
Even if they had gaskets on them, were they good? Were the screws tightened up correctly. Those darn things leak pretty easily. How long ago was the last time you checked the oil? If it was a few years, well......
If it has been a while and you are not positive everything was top-notch with the plugs and gaskets - Drain, refill, (perhaps drain again to make sure you got the water out) and run for a short while to see if water gets back in. Make sure you have the proper gaskets (and they were new) and everything is really tightened down correctly. Those who know on this site recommend these gaskets be replaced every time you change your oil.
If you know everything was correct with these screw plugs and gaskets, then it's a bigger issue as you suspected
But as suggested, don't mess around with the issue and take it lightly so you don't have a bigger problem on your hands.
