Ebrooker007
- Joined
- Dec 3, 2012
- 19
I have a 2002 mercury 90 hp two stroke. I rebuilt the motor this past winter and took in out in the spring and it ran great. I haven't taken it out in a few months so I took it out yesterday. The boat ran great for a while and I thought but then it would not rev past 4000 rpms. So I thought maybe I had fouled a plug or something. So when I took the plugs out the middle cylinder had some water in it. Then I run a compression check. It showed 115 on the top and bottom cylinder and 75 on the middle cylinder. I also have not run it hard since the rebuild. I used the break in procedure I found on here.
I think it is something bad but is it possible it is just a seal and maybe I wont have to tear the motor down completely again. I'm worried the block might be cracked. I did have a boat machine shop hone the top and bottom cylinder and resleeve the middle cylinder. Anybody have any thoughts as to what might be wrong.
