Water in my gear oil
JF660R
We have a StarCraft with a '76 Merc 850 Thunderbolt, the SN is 4537364. Just got the boat this year and have had it out 4 or 5 times.
We immediately installed a new water pump kit. We are currently draining and refilling the lower unit oil before every trip. The oil comes out an off white color every time.
Looking for input on which seals we need to buy / replace. Part #s or sources would be really helpful. Wanting to make sure I order the right parts.
Thanks
Re: Water in my gear oil
Order a complete seal kit.---This site and other sites or your local friendly mercury dealer.
TD_Maker
Racerone is correct. At this point I would go ahead and replace all the seals on the Gearcase. Don't forget not to use the filler screw seals more than once. These little plastic crush washers have caused many leaking lower units. If you really need to know about an individual leaking seal, I would rig a pressure tester or vacume tester. They will tell the story.
Chris1956
The seal in the waterpump base is the prime suspect, in my experience. Drop the gearcase, remove waterpump cover, impeller and wearplate. Now sand the driveshaft to remove any rust, and lube it with oil. Pry up the waterpump base and replace it with a new one. Make sure you lube the seal in the pump base before installation. Now reinstall the wearplate, gaskets, impeller and pump cover.
JF660R
Look for the proper seal kit from sierra.---You might look for a kit for the 80 hp model.--18-2653 comes to mind.
8o hp or 85 hp is all the same lower unit.
