Water in my VRO tank...best way to bleed the system?
Found water in my VRO tank? Where could it have come from? Whats the proper way to purge the VRO system of any water?
Chris1956
Re: Water in my VRO tank...best way to bleed the system?
The water can come from condensation or a leak in the cap. You need to "suck" it out of there. I have used the pump from the gear oil bottle to pump the water off the bottom of the oil tank. I also used a spare primer bulb and a piece of fuel line to suck up the water. Pump it into a clear container and the oil will seperate from the water and you may reuse the oil.
WillyBWright
Before you bother, make sure the damage hasn't already been done. Do a compression test. If it's okay, immediately mix your fuel supply at 50:1.
Water gets in from exposure to rain or boat spray, condensation, or submerging in water that might have covered it. Leaving the boat plug out while in the water and filling with water comes to mind. Leaving the boat plug in while out of the water and filling with rain comes to mind.
Shake it up good and dump out the oil and start with fresh. Allowing it to separate in a container works if you want to do that, but a fresh tank of oil isn't going to kill you financially. Follow the oil line to where it enters the pump and disconnect it there. Then pump the fresh oil through until it's all the way through the line and reconnect. Be careful, the fitting is plastic and it can break.
I'd also advise draining the carburetors and forcing fresh fuel through the system until the premixed gas comes out, then putting the drain plugs back in and run the motor.
Realize that if there's water in there now, it's probably been in there awhile. Your motor might have already been getting water instead of oil. That's the leading cause of the overly maligned "failed" VRO pump. Most of the time by far, powerhead failure due to lack of lubrication isn't the fault of the pump, but the fault of what it's pumping.
tashasdaddy
if you have water in it. dispose of the oil, don't try to save it. it's the engines life blood, compared to a rebuild oil is cheap. clean the tank, disconnect hose at the pump, then use the primer bulb, until all air is out of the line and all you get is oil. reconnect.
Thanks for the quick info. I purchased this 1986 Hyrda Sport w/200hp Evinrude from a auction and really don't know the history.
