water in oil 4.3 inboard jet
jfitchett
I'm new to boating and to this site.
I have a 4.3 Kodiak inboard attached to an American Turbine Jet. I have 30 Hrs. on the boat/motor. Yesterday the fresh water intake hose for the heat exchanger came off while at full power. I lost all power but motor kept running, lifted doghouse, re-attached hose and re-gained power. I ran boat for another 5 minutes to dock, put on trailer, checked oil and it was milky. Any thoughts? My dad thinks it is a head gasket, my buddy thinks it ingested water through carb. ???
Thanks for your time.
BTW...once the hose was re-attached it had as much power as when it was new. Can water enter the oil pan via the carb? It went back to the dealer today...we'll see
Re: water in oil 4.3 inboard jet
Ayuh,.....
I guess it would be time to Pressure Test it,+ See which it is...........
Btw,.....
Welcome Aboard.....;)
Your dad is probably right,if your lucky.Other possible cause is a cracked head.Either way the heads will have to come off.I would also check compression for collapsed rings.
180shabah
Your dad is probably right,if your lucky.Other possible cause is a cracked head.Either way the heads will have to come off. I would also check compression for collapsed rings.
Before removing the heads ;)
