Re: Water in Oil MCM165 Mercruiser
Ok this is getting a little frustrating... I wish something would just show up broke. The riser is a water resevoir and exhaust elbow combined. I closed off the holes and filled the resevoir.. left it sitting for hour or so.. no water in exhaust chamber. Turned it over filled the laket water side untill it started coming out of ports in lower elbow where it injects into exhaust... no water shower up in upper chamber. Scrapped aggressivly with screw driver, seems solid. I cannot find the smoking gun.
Here is what I know... I had water blowing out cylinder #4 with plug out and I have lots of water in my oil when I drained it. By the way how do I get all that water / oil out of the oil pan before I start going back together?? Hindsite is always 20/20 and I wish I would have done more listening before I tore it down so I could have done more test, but when you have water coming out a spark plug hole and water in the oil it pretty obvous it has to come apart. So couple questions, any way to pressure test the block with heads and manifolds off and does anyone have a 1,2,3 checklist for me at the stage I am at?? Head checked out good, had pressure tested, reworked valves and ground surface. ready to go back on. It was not the head.
